Hey can you help me with my loops?
What i'd like to be able to do is to set loops which automatically start in the track - much like the cue points.
I like to set loops at the end of my tracks which I use to mix into the next track.
Problem is that when the out going track is playing it's hard to get the exact loop point correct and sometimes I miss it.
It's easy to do it at the start of the incoming track but not so easy on a track playing....
I'd like to preset this loops so i don't have to worry about it in the mix and it auto loops (until I release it)
Is there a way to do this?
I'm using vdj 6, RMX and multifunction 6.1 skin
Thanks
Thanks
geposted Mon 23 Aug 10 @ 5:46 am
geposted Mon 23 Aug 10 @ 6:16 am
