Another one, can you help me with the bass slider
Using Multifunction 6.1, RMX and VDJ 6.
When i'm using the RMX Bass EQ's I find that sometimes when even just turning the Bass EQ a little it just kills the bass.
Or just cuts the bass too much and the out going track volume is really effected.
I've found the bass slider in multifunction 6 is better for just swapping over the bass.
I like to take a long time during the mix transition so would like the bass swap over to be as smooth as possible.
Is there a way to assign the bass slider to something in the RMX ? This would make it easier than using the mouse.
Thanks
Thanks
geposted Mon 23 Aug 10 @ 5:53 am
you can try to link it to the crossfader. play with different setting under the mapper tab in setting
you can modify the default values for your RMX
geposted Mon 23 Aug 10 @ 9:09 am
