Using VDJ 6.1 Pro + Numark Total Control. The local mix is fine, but when I listen in on the stream broadcast, there is a stutter/skip/click that happens as the two tracks are being mixed together...almost like it loses the sync over the stream (even though it's perfectly synced up in my headphones locally). Once the track on one deck is finished playing, the second track is streamed and sounds fine over broadcast.
As I said, the mix sounds fine locally...it's just over the broadcast that this happens. Does this sound like an issue with the hosting stream server handling the multiple tracks or is there some kind of latency setting I should change? I thought about connecting at 96kbps instead of 128 just to see if that made a difference, but haven't checked that out just yet.
For the record: I've tried that latency checker while running VDJ and it's never shown a problem with latency. I'm using a desktop, 4GB RAM, Xeon quad-core...the desktop specs are more than enough to handle VDJ (which explains, to me anyway, why the mix sounds fine locally).
geposted Mon 23 Aug 10 @ 3:06 pm
