Hi.
I've searched the forum for info about showing the effects settings in the skin.
I.e. if I select the CUT effect, I like to se if the parameter is set to 1/4, 1/2, 1/1 beat and so on.
And I want to se the info right beside the selected effect, not have to click the Effect tab firts.
Also I like the selected loop length to be marked "like a pushed button" also when not activated.
Then I will know what loop length it will be before I push the loop button.
Is this possible?
//GSL
Is this possible?
//GSL
geposted Mon 23 Aug 10 @ 6:11 pm
Not sure about the first point but you can do the loop.
You'll need a textzone in the skin with '%loop' as the verb.
geposted Mon 23 Aug 10 @ 6:33 pm
