Hi everyone,
Up to last night everything was working file. I was updating and down loading cover art however, just now I notice I can't...
Here is what I what I have checked already:
>>> Firewall has always been on but I turned it off to see if that would help... This didn't help...
>>> Config, Browser, "change to" Down load no matter what... It didn't help...
I also notice that song which already what there cover down loaded is also showing "No Matches" all off search boxes...
When I first open VDJ and select to search for a cover. VDJ starts to search but quest stops and note "No Matches" across all fields.
Again, I didn't change anything until VDJ stop searching for covers...
What else should I be doing...
Thanks...
"This is to help me better find my post"
CadDogCoversStopped
Hey...!!!
Another thing I just notice...
VDJ stopped asking me to down load the new update...!!!
I didn't want to down loaded until I had work with it a while but
Now it stop asking...
It there a time limit on now many time I can so no...???
I'm wanted to end this in case it also has something to do with my cover not down loading...
I still have VDJ 6.1.1... I haven't down load the new one yet... Just to me clear...
Thanks again
Thanks...
CadDogCoversStopped
Hey...!!!
Thanks again
geposted Mon 23 Aug 10 @ 8:06 pm
I think I found the answer but I still don't how to fix it...
Under Config, Internet....
It's states:
"No Internet Connection"
How to I get VDJ connect...???
As you can see, I'm connected with this laptop and everything else is working...
I'm sure that is the problem...
I did install a new external hard drive yesterday and copied all my music files over on to it.
Once it finished I worked for a few more hours adjust music file locations and down loading covers.
However, today when I start VDJ I notice the no inter connection...
I hope this helps you help me... :o)
Please Help.
It's states:
Please Help.
geposted Mon 23 Aug 10 @ 9:33 pm
Do you think I need to uninstall and re install VDJ
in order that VDJ finds the internet connection again...???
Thanks (Just trying to myself but I'm not doing anything until someone else gives me answer. I don't want to dig myself into a hole...)
geposted Mon 23 Aug 10 @ 9:40 pm
WOW...!!!
You guys are good...
I couldn't wait and continue to mess around and found the answer...
Config, info,
Down load Plugins...
Once I did that it asked me a question which I remember say no to before...
This time I said yes and got re-connected...
Add my password and working fine as always...
Thanks for being here...
:o)
Hey, this beats talking to myself... hahaha
Config, info,
:o)
geposted Mon 23 Aug 10 @ 10:07 pm
