how much$
what retailers have it ....i'd like to just go in my Sam Ash ......
can it do tcv and tccd with VDJ ?
how do you use it in analog mode ?
geposted Mon 23 Aug 10 @ 11:33 pm
About 500USD, give or take 50. Mine is expected around Oct. 10th My American Audio dealer tells me there is a pretty big back order. I'm sorry Chuckles, no answer for you on the last two.
geposted Tue 24 Aug 10 @ 6:31 am
Yes, it's been designed to do exactly that, depending on how you set the sound card
switch on the front panel.
In the "4 out" (4 in/4 out) position it will send the TC signals from inputs 2 & 3 to the computer.
In the "8 out" position it will allow four stereo outs from the computer.
geposted Tue 24 Aug 10 @ 8:03 am
For analogue mode you just toggle the switch on the front panel from USB to Analog - there's one for each channel.
This can be done on the fly, without shutting down the software. Obvously in analog mode the CDJ or turntable act as they were designed. Flick the switch to USB and they become TC's on the given channel.
Cheers,
Roy
Cheers,
Roy
geposted Tue 24 Aug 10 @ 9:02 am
