How Can I save my cue points when I transfer my libary to other hard drives my cue points disappear.
geposted Tue 24 Aug 10 @ 12:48 pm
Back up your xml database and you should be good to go.
Huey
Huey
geposted Tue 24 Aug 10 @ 12:57 pm
ty for responding....................I don't know how to do that bro can u help me out
geposted Tue 24 Aug 10 @ 1:08 pm
Im doing this all from my phone, lol! Read like the 3/4 post down from the link im gonna post. If you still can't figure it out don't do anything and ill post a step by step when i get home. https://virtualdj.com/forums/132408/Wishes_and_new_features/New_feature_idea__Auto_backup_of__xml_database_files_.html?search=backup%20the%20database%20&page=1
Hope that helps
Huey
Hope that helps
Huey
geposted Tue 24 Aug 10 @ 1:29 pm
thx dude I appreciate it.
geposted Tue 24 Aug 10 @ 2:29 pm
OK, go to C:\Users\xxxxx\Documents\VirtualDJ and look for a file named "VirtualDJ Database v6.xml". Next right-click on it and hit copy. It will seem like nothing has happened but trust its copied now. Next open whatever folder your going to save it to and right-click again and hit "Paste". Boom there it is.
See nothing to it. You should do this about once a week anyways so incase something happens you always have a fresh copy and dont have to worry about re scanning all your tracks again. Also put it some where other then your gig machine. If that goes then all of that backing up would be for nothing, know what I'm sayin............
Hope this helps
Huey
Hope this helps
Huey
geposted Tue 24 Aug 10 @ 4:31 pm
THX IMMA TRY IT OUT BRO ALSO IMMA SEND U A FRENZ INVITE////////GOOD LOOK
geposted Tue 24 Aug 10 @ 4:43 pm
Don't forget to backup all your music drive databases. These XML files are in the root directory of each drive. Easy to find.
I wish VDJ would come up with a naitive macro that would push everything to a networked back-up machine, and be able to clone with 1 or 2 button clicks. Right now it's a chore.
I used to run 2 machines with XP and cloning was achievable. Now one is Vista (yuck) and the other is XP. I had to move to Vista because of video playback issues on the laptop. Now things are a bit more complicated to clone. Actually I haven't tried the XP<>Vista clone project yet, but I should do it as next project tonight.
It would be nice to have a simple way to move current work from my studio PC over to my gig Laptop. I'll spend hours on my Studio PC and then could definetly use a quick effortless way to transfer this work to the gig machine. You know like Virtual folders, Filters, Samples, Cue Marks... etc.
The need is to focus more time on the music and not as much time on the mechanics. Backups on these gig computers should be a major focus point. We all know how easy it is for something to go wrong with this stuff. Any why manually duplicate one machine to another when this can be done via programming.
Vote Versiion 7.000001 the cloning release. :)
JJZ
JJZ
geposted Wed 25 Aug 10 @ 12:10 am
@ Beatbreaker, Ithink it worked I experimented on it for awhile last nite and I believe it's done good look. @Jimmy..I feel you dude....back up is very important. Version 7.0 of Virtual DJ is "BANANAS"
geposted Wed 25 Aug 10 @ 11:47 am
Nice!! Glad it worked!
Huey
Huey
geposted Wed 25 Aug 10 @ 12:12 pm
