will this work with vdj, and is it worth it?
geposted Wed 25 Aug 10 @ 6:12 am
Yes it work, it's a common usb mini card with an headphone connected inside.
geposted Wed 25 Aug 10 @ 6:41 am
can i cue up and listen as if i had a mixer board?
geposted Wed 25 Aug 10 @ 8:23 am
never mind. i got the Behringer U Control UCA202 USB Audio Interface instead. i hope this was a wise choise.
geposted Wed 25 Aug 10 @ 10:40 am
did you like your choice with behringer?
I am just about to decide about a sound blaster /audio interface or these usd headphones, so may you have some suggestions, please pass.
Thanks
Thanks
geposted Tue 01 Mar 11 @ 4:27 pm
it depends on what u want to do. im a garage dj/remixer so i just wanted something cheap that does what i wanted it to do. now if you are going to dj in da clubs or special events i would rec/mend that you spend the money on something a little more high end. you dont wont to be caught with humms and hisses. oh, to answer your first question, i do like the berhinger. like i said it is cheap ,but worth it to me.
geposted Wed 02 Mar 11 @ 5:46 pm
