Hi there, I am going to buy some Kam turntables and mixer and was wondering if my laptop will be able to handle VDJ. I have a Intel dual core 1.5ghz, 2GB Ram, 120GB Hard Drive and a Mobile intel 965 express chipset. Thanks
geposted Wed 25 Aug 10 @ 10:28 am
yes your laptop should hadle virtual dj i would not video mix with it thoe it will not handle that to good but audio you should not have a problem another thing you need to find out is if vdj can handle these turntables i dont know if vdj supports them.
geposted Sun 29 Aug 10 @ 4:37 pm
What do mean?? Theres nothing special about those turntables. They only have 2 models left the other 4 are discontinued, like most of there stuff. Unless your talkin about the USB tables, which I would hope hes not getting cause they are Belt Driven tables.
Just my 2cents
Huey
geposted Sun 29 Aug 10 @ 6:31 pm
