hi i have just purchased vdj 6 pro, and am going to use it for mobile discos, was wondering what the best automix setting is or is their any others u can download? thanks graham
geposted Wed 25 Aug 10 @ 3:48 pm
Automix is meant to be used to 'assist' the DJ. Ie looking break or background music. It's not meant to replace you or what you do to play mix music.
Are you new to DJing or are you moving from CD/vinyl to digital?
Cheers,
Roy
Cheers,
Roy
geposted Wed 25 Aug 10 @ 4:08 pm
