So i read the boards a lot and i thought i was following the instructions but i guess I am not.
I have the dj console rmx with audio interface just bought it the other day. what i want to do is use my laptop speakers to hear the music using the device i did buy a rca male to 3.5 mm jack female plug but im not sure if i have it plugged in right can someone please help me. Thank you very much.
geposted Wed 25 Aug 10 @ 4:50 pm
Hello. If you have the output setting in VDJ to mono split then a stereo out on your laptop, (3.5 with a headphone symbol next to it), would have a main out mix on one channel & the cue output on the other. What soundcard are you using?
geposted Sat 28 Aug 10 @ 9:41 pm
The version of VDJ included with the DJ Console will only with the Rmx soundcard.
This means that it is necessary to connect your speakers and headphones to the appropriate connections.
If you absolutely have to use the computer integrated speakers, try this:
- Connect a cable from Output 1/2 of the console to the LINE input of the computer
- Download LineIn from this page:
http://www.rogueamoeba.com/freebies/
- Run LineIn, leaving everything as default, and click Pass thru
You should now get the main output mix from the MK4 in your speakers
geposted Mon 30 Aug 10 @ 9:21 am
