Is it built into the software? Just wondering. I may pick up a pair from a freind for cheap! Are they worth 300 for the pair? Thanks in advance..
geposted Thu 26 Aug 10 @ 11:09 am
Go to your Config -> Mappers tab. Click on the button to the right of the drop-down box and uncheck the 'Show only Connected devices' - then you will see the entire list of supported units.
And Yes, the NDX800 are supported.
geposted Thu 26 Aug 10 @ 7:35 pm
Thanks C!!
geposted Fri 27 Aug 10 @ 8:15 am
