I'm assuming this is will sort my problem out of timecode slipping.
Is this the same as VDJ?, all the same settings and features, but is suitable for those who want to scratch? and alot more stable then VDj it self?
Has anyone got this, and would recomend this?
Thanks
Thanks
geposted Thu 26 Aug 10 @ 6:18 pm
It is the same software as Virtual DJ however the timecode interface box was specifically designed to offer a low latency interface for Virtual DJ.
Which sound card do you use now? You will likely find the slipping is due to environmental factors.
geposted Fri 27 Aug 10 @ 9:06 am
I have a Maya44 and a hercules RMX.
Would consider upgrading to NI Audio DJ 4 if its simular spec and if it fixes the problems.
what do you mean environmental issue?
Thanks
geposted Fri 27 Aug 10 @ 2:08 pm
Thanks
Thanks
Needles, soundcard, cables or worn records.
Try dusting the records and check the needles are ok. If the signal fluctuates it can lead to problems check the quality %
geposted Fri 27 Aug 10 @ 2:43 pm
Needles = Brand New
Sound Card = RMX/ Maya44
Timecodes = Brand New
I'm afraid its a VDj problem.
The % quality reads 99%. 99% of the time.
geposted Fri 27 Aug 10 @ 4:26 pm
I doubt its VDJ. I have a maya44, sl1 and the numark box and I get 100% signal 99% of the time with any of them. Just keep tweaking your settings. What kind of tables are you using? Not that that matters just curious.
Huey
Huey
geposted Fri 27 Aug 10 @ 8:37 pm
Huey
Huey
I was thinking the stylus need's bedding in, loose there stiffness?
Nothing special, Stanton T.60.
geposted Sat 28 Aug 10 @ 9:58 am
