SOoo,Im still Running on V.6.07 or something.avoided updating untill the smoke cleared but...should i go for 6.1.1 or wait for version 7 too arrive?
geposted Fri 27 Aug 10 @ 10:01 pm
I'm still on 6.08, not changing till all the video stuff gets worked on.
geposted Sat 28 Aug 10 @ 1:42 am
What video stuff? It works fine for me.
Huey
Huey
geposted Sat 28 Aug 10 @ 2:33 am
@bryan, I stuck with 5.2.1 right the way through up until v6.1 was released, then moved over to it a couple of month back, been sweet for me all the way.
Best thing to do is keep a copy of what your using and when you have a break in your gigs install v6.1 and try it out, is the best advice I can give you, even if you don't like it you can still go back to the old one your using now.
geposted Sat 28 Aug 10 @ 5:15 am
With updates for any software its logical to try it out when you do not have any events for a little while and see how it performs with your system.
geposted Sat 28 Aug 10 @ 11:18 am
Updates would be the solution to many issues, of why some applications do not work? it would be advisable, and logical to upgrade, when available.
geposted Sat 28 Aug 10 @ 4:31 pm
True just dont do it the night before a gig :-)
geposted Mon 30 Aug 10 @ 8:10 am
That's true with everything...
A couple of years ago I upgraded my iTunes the morning before my gig...
But Apple is the ROCK...!!!
No it isn't or it wasn't that date...
It told me 3 hours to remove, find and re-install back to an older version...
Why, you may ask...
Somehow when I installed the newer version of iTunes my DJ software stop working...
And going back in time didn't help...
So Never install or upgrade anything before you have a chance to totally check it all out...
geposted Mon 30 Aug 10 @ 8:15 pm
