hi
when I open Vdj it tells me the skin I selected has a higher resalution how I fix this
geposted Fri 27 Aug 10 @ 10:48 pm
GO Config - Skins and select a skin with a different resolution, a smaller, than what you've selected now
geposted Sat 28 Aug 10 @ 5:05 am
I don't see config on Vdj Le
geposted Sat 28 Aug 10 @ 10:46 am
What resolution are you running your screen at?
geposted Sat 28 Aug 10 @ 12:12 pm
I can't remember it came preset from dell
geposted Sat 28 Aug 10 @ 12:17 pm
I checked my screen resalution and its set at 1400 by 900
geposted Sat 28 Aug 10 @ 5:50 pm
there is only one skin to pick from on vdj LE how could it use a high resalution
geposted Mon 30 Aug 10 @ 3:15 pm
