Im having problems with Virtual 611 most times when i open the program a box opens up saying error in the asio sound card driver not enough channels,im using Numark dj aio sound card,i have never had this problem before when i was using Numark Cue software,and im using the same laptop on vista,the sound does sound quite distorted,what is the best setup??
geposted Sat 28 Aug 10 @ 7:54 pm
Under Config in the Sound setup area, what do you your Output set to?? If you have it set to 3 lines mixer and your soundcard only has 2 channels you will get this error messages until you set it right.
Hope that helps
Huey
Hope that helps
Huey
geposted Sat 28 Aug 10 @ 8:40 pm
