Hi Guys, does anyone know what the best settings are for the audio latency on Dj IO for virtual,at the moment they are set on 1024 samples 35.8ms/62.5ms, i think this is the highest it goes? is this too high?
geposted Sun 29 Aug 10 @ 9:00 am
There is no perfect setting, each computer will allow you to set a different value. Its linked to your performance.
Try setting the minimum see if it causes drop out and then move the latency up until you stop getting dropouts to find your perfect value.
Note that 1024 may not be an issue if your not scratching.
geposted Mon 30 Aug 10 @ 8:04 am
