Hi,
On the new 6.1.2 version of virtual dj I have an issiue where on some songs the pich changes when I mix across to the other deck,
is there any setting for setting that the pich is just set at zero for both decks and doesn't drift up or down when mixing from deck to deck?
geposted Sun 29 Aug 10 @ 12:21 pm
try go to options and disable pitch match
geposted Sun 29 Aug 10 @ 2:16 pm
I've tried that and it makes no difference mate
geposted Mon 30 Aug 10 @ 4:54 am
have you got the key lock activated(lock symbol under deck).
what controller are you using could it be something there a mapping issue maybe
geposted Mon 30 Aug 10 @ 2:19 pm
Does the key lock have to be activated?, I think it is I will check and get back to you.
Thanks
billy24
Thanks
billy24
geposted Tue 31 Aug 10 @ 4:17 am
i think it keeps pitch/keys matching when you load and mix tracks.never used it so not sure mate.trying to help in little bib by bit breakdown way lol
geposted Tue 31 Aug 10 @ 2:30 pm
I was at a gig on Saturday and The SAME THING HAPPENED TO ME with the new version. Is it possible there is a glitch in the software. Should we go back to the older version until it is checked into??
geposted Thu 02 Sep 10 @ 6:20 am
