I keep getting asked to do it. I updated it twice but the pop up keeps asking me to update.
What the heck?
What the heck?
geposted Sun 29 Aug 10 @ 1:58 pm
Which Popup ? Maybe it askes you for updating you Hercules drivers ?
Greets, Heiko
Greets, Heiko
geposted Sun 29 Aug 10 @ 2:07 pm
go to options and uncheck search for updates id say
geposted Sun 29 Aug 10 @ 2:08 pm
Check the Info tab next time you run VirtualDJ ... if you are not running version 6.1.2 then you are not running the latest version and that is why you keep getting the notification to update.
And you can turn it off as mentioned above, if you want.
geposted Sun 29 Aug 10 @ 2:49 pm
I've updated twice, last week & yesterday so it has to be running the latest.
I'll see if I can I can do what they said above.
geposted Sun 29 Aug 10 @ 7:20 pm
no matter what I do it keeps asking me to update. I've updated it 3 times & fix settings & same thing.
geposted Wed 01 Sep 10 @ 10:21 pm
When you say 'updated', did you just download the file from the VDJ site or did you actually install it?
Some apps will download and install updates. VDJ simply directs you to your software updates page. It's down to you to actually install the file...
Roy
Roy
geposted Thu 02 Sep 10 @ 2:04 am
downloaded & installed 3 times.
geposted Thu 02 Sep 10 @ 6:31 am
You are a Mac User right?
Are you running VirtualDJ from your Applications folder?
If you pulled the App from the folder (and not create an Alias that you pulled) in the past and put it on your desktop area or in your Dock then you are still running an old version. Again, once you open VirtualDJ, go to the Info tab and look at the version number - I guarantee you are running an old version.
geposted Thu 02 Sep 10 @ 7:05 am
Try to delete the old VDJ desktop shortcut and then install the update.
geposted Thu 02 Sep 10 @ 10:28 am
