Is there a way to map effects to a button/knob on a MIDI controller? From what i gather you have to hit the drop down menu, select the effect, either activate it or click and hold on the effect knob in the interface. i have a Novation remote 25sl MKII and i have a bunch of unused knobs
geposted Mon 30 Aug 10 @ 11:14 pm
You sure can just go into mallets and then select your button or knob then type out the script. Nothing to it.
Huey
Huey
geposted Tue 31 Aug 10 @ 12:25 pm
If you're using VDJScript:
If you want to map an effect (lets say Flanger) to a button:
Effect 'flanger' active
This will turn on and off the flanger effect when you press the button. for other effects use the name of the effect in the dropdown-menu
To make a knob activate and effect:
Param_greater 0% ? effect 'flanger' active on : effect 'flanger' active off
This will turn on the effect when ever the knob is turned higher than the minimum, and turn it off when the knob reaches minimum,
geposted Wed 01 Sep 10 @ 6:01 pm
