Hi guys, total noob.
I have 2 cdj400 set up with a behringer djx700 mixer. Everything works ok until I try and record a live mix. The problem is that its playing the tracks being cued as well as the live track. I have worked out that its to do with the crossfader on virtual dj always being in the middle. Is there a way round this? or do I need a different mixer etc?
Any help would be greatly appreciated
Thanks
Thanks
geposted Wed 01 Sep 10 @ 2:14 pm
sorry guys just found half the answer,
I need to take lead from mixer to line in on sound card. (is this the line in on my computer?)
It says when I try to record now ** record error ** souncard unavailavle?
Any suggestions?
Thanks
Any suggestions?
Thanks
geposted Wed 01 Sep 10 @ 2:32 pm
You need to tell your OS which device it must use for recording. If you are on a Windows you should go to control panel/sound and select there your desired card and port for recording.
geposted Thu 02 Sep 10 @ 2:33 am
