I just purchased the hercules mk2, its coming in on Saturday. I was wondering if someone could explain to me exactly how to connect to the my A/V equipment. I know how to connect it to my laptop, just alittle confused about the hook up to my amp.
First i'm using
1. Pioneer VSX-1015 a/v receiver as my amp
2. Virtual Dj Pro 5, with mixlab skin (forget which version it is)
3. Toshiba satellite laptop.
4. hercules mk2
The thing that i'm confused about is the connection of the mk2 to the amp. Theres 1/2 rca and a 3/4 rca both outputs. Do I have to bring them together as one on my input on my amp, to play both decks together? Or just only use one of the 2 to play both decks?
The other question i had is, will the virtual dj pro 5 work with the mk2? will the mixlab skin i use work with the controller?
Thanks for your help, Dave
First i'm using
4. hercules mk2
geposted Wed 01 Sep 10 @ 4:51 pm
see your other post on the subject.
geposted Thu 02 Sep 10 @ 6:41 am
