Hi to all, i'm new here and i'm from argentina, so let's make clear my english is not the best one out there =P
My question is...
Is it possible that, when I plug my hercules rmx to my pc (win XP), change the default WMD to ASIO (in the HDJC pannel), then open the Virtual DJ, change the settings to ASIO driver, and then the only way to listen to music in my pc is out of the Virtual DJ, no winamp, not wmp???? i'm pretty sure i was able to do that the last time i tried (a month ago).
thanks!!
My question is...
thanks!!
geposted Wed 01 Sep 10 @ 6:36 pm
Most audio players (Wimamp, WMP, iTunes) do not support ASIO, so it is necessary to have the console set to WDM to use these applications.
geposted Thu 02 Sep 10 @ 6:45 am
Unless you specify the output from VDJ to go to your internal sound card, it will always route the sound to the sound card in the RMX.
Cheers,
Roy
Cheers,
Roy
geposted Thu 02 Sep 10 @ 3:52 pm
