Hope somebody can help with this. When I used to use version 5.2 with the 'Boggis' map for my Dac 3 the numbers 5,6,7,8, on the controller used to give me fixed length loops (if I recall 5 was one beat, 6 was 2 beats, 7 was 4 beats, 8 was 8 beats, and so on).
I have now upgraded to 6.1.2. and the map that works the Dac3 no longer seems to do this, I have to set loops by using the loop in / loop out buttons. The numbers all seem to set cue points.
Anyway I can get this back to how it used to work with the Boggis map?
Cheers
Cheers
geposted Thu 02 Sep 10 @ 10:21 am
Hello mate!
If you want I can swing by tomorrow before work and help you set things up? I'm no longer working daytimes ;)
Basically you want to use the mappers window to map the buttons on your controller.
By default 1-10 control hotcues 1-10, unless used with Shift in which case they do loop control.
If you select the DAC3 you'll see these buttons, and you could just change them to 'loop 4' for example.
geposted Thu 02 Sep 10 @ 3:37 pm
