Hi guys not been on here for a while.
I have had a problem for a while now with my RMX, the up key doesnt work and the only way i can go up through tracks is by holding down key and using the jog wheel :(
Any advice or help would be great
Thanks
Adam
Thanks
Adam
geposted Fri 03 Sep 10 @ 11:07 am
Is this a problem only in VDJ or did you also confirm as a hardware defect, by using the following procedure:
http://ts.hercules.com/faqs/eng/her_eng_00353.pdf
geposted Fri 03 Sep 10 @ 11:11 am
oh thanks i didnt know about this, i will go through the procedure and let you know what the results are :D
Thanks
Adam
Thanks
Adam
geposted Fri 03 Sep 10 @ 11:21 am
right i have run the test and gone through all the buttons on the rmx and they all have the same value between 0-127 so it seems the buttons are working fine.
What could it be?
possibly the vdj version i have?
Thanks
Adam
What could it be?
Thanks
Adam
geposted Fri 03 Sep 10 @ 11:30 am
Curious if you did the VDJPro Trial and my have "fat fingered" the "up" key mapping while it was active. Im not sure if the files are all the same for the VDJPro and LE edition.
Off the top of my head, check the file at Documents/VirtualDJ/Mappers and there may be a HerculesRMX .xml there. I am not sure if it will be there or not since your using the LE edition but worth a shot I think. If it is, open it with notepad, find the "UP" key entry and copy/paste the line here. While your there copy/paste the "DOWN" key also.
Anyone else wanna chime in?
geposted Fri 03 Sep 10 @ 6:14 pm
