Hi
Im really hoping someone will be able to help me here.
Im having an issue with track not fully loading, after using VDJ for around 2hrs or so if i load a track that is 13min long it wont full load up. Will play fine and till the end but then any size track that i load be it a 4min track VDJ will just not fully load the track. Yes i do have the track load in config set to max but dosent make any diffrence. So in the end i have to restart VDJ to resolve the track load issue.
Also everytime a load a track even if i have just started the gig VDJ will freeze for 1 second.
Here are the specs:
Hp Windows 7 64bit
4g Ram
External HD 500g with 300g of music
Latest VDJ software
CDJ400 decks
DJM mixer
Hope someone will be able to help.
Thanks Rob
Here are the specs:
Hp Windows 7 64bit
4g Ram
Latest VDJ software
CDJ400 decks
DJM mixer
Thanks Rob
geposted Sat 04 Sep 10 @ 3:31 am
randrade wrote :
Hi
Here are the specs:
Hp Windows 7 64bit
4g Ram
Latest VDJ software
CDJ400 decks
DJM mixer
Thanks Rob
Here are the specs:
Hp Windows 7 64bit
4g Ram
Latest VDJ software
CDJ400 decks
DJM mixer
Thanks Rob
I really need some help here folk, thank you in advance.
geposted Tue 07 Sep 10 @ 3:08 pm
i had the same problem... after few hours playing, the waveform was not fully loaded, and i need to seek the track till his end, to see the correct track time and waveform...
geposted Sun 12 Sep 10 @ 10:09 pm
