Hi,
I currently use the Numark Total Control controller with the VDJ software.
I am looking to upgrade and quite fancy the RELOOP DIGITAL JOCKEY 2 (Interface or Master edition), is it any good?
I use most of the functions on the Numark including the buttons to fire the samples/jingles. I'm assuming the Reloop will do all this and more.
Does anyone use the Reloop controller with the VDJ software and can you recommend it. Reloop recommend the Tracktor software but I haven't used that before and I'm now quite fond of the VDJ.
Thanks
Phil
Thanks
Phil
geposted Sat 04 Sep 10 @ 2:32 pm
Go buy, practise and enjoy @
Have it since it came out here in the Netherlandsw. I use it in both software packages mentioned by you. However using VDJ script it is really easy to meet your own demands. In other packages it is more cumbersome to figure it out as a beginner.
geposted Mon 06 Sep 10 @ 4:46 pm
