I went over to the Serato website and found this on their site:
http://www.novationmusic.com/uk/products/digital_dj/dicer/
HOW COOL!!!!
But how would it only work with Serato if its USB interfaced?
I'd love one of these. I have been looking for something like this for months with multiple CUE points and loop buttons.
HOW COOL!!!!
geposted Sat 04 Sep 10 @ 4:13 pm
And support in VirtualDJ since 2 August - thanks to cioce ...
https://virtualdj.com/addons/11828/Novation_Dicer_Def___Mapper.html
geposted Sat 04 Sep 10 @ 5:06 pm
Wow..
That is so cool!!!
Thank you!
geposted Sat 04 Sep 10 @ 5:50 pm
I purchased one today.
Not impressed with the mapping. Its nothing like it :(.
What VDJ script would i type for 'Loop roll'?
Thanks
Thanks
geposted Sun 05 Sep 10 @ 9:49 am
I'm going to re-map it, exactly like how the dice should be.
Expect a upload in the next few weeks.
geposted Sun 05 Sep 10 @ 10:00 am
you better off with a korg nanopad or nano kontrol. more options IMO
geposted Sun 05 Sep 10 @ 10:31 am
I said supported - not mapped exactly like Serato mapping :)
And, it's a MIDI controller - so the mapping is of your choosing. And that mapping you downloaded is of one persons choosing and design. Which you are freely able to change if you like and sounds like you will.
geposted Sun 05 Sep 10 @ 12:10 pm
True statement there, love my NanoKontrol!!
Huey
geposted Sun 05 Sep 10 @ 12:12 pm
I'm sorry if i sounded like i was offending you, i didn't mean it at all like this.
I'm having problems with the Cueing + rolling loop.
geposted Sun 05 Sep 10 @ 12:36 pm
Look at this Thread - i think it will help: https://virtualdj.com/forums/131515/Hardware_Technical_Support/Novation_Dicer_midi_controller__Def___Mapper_now_available_.html
geposted Sun 05 Sep 10 @ 12:38 pm
