All,
Is it just my version or does the "DUMP" effect not work anymore in Virtual DJ V6.1.2. Mine just seems to do a reverse and not jump forward like it is meant to!
For your information lifed from VDJ WIKI:
dump : reverse the playback direction while dump is active, then when deactivated, start again forward from where the song should have been if it had been playing forward during the dump.
Anyone know how to get this working again or an alternative method?
Cheers
Daniel
Cheers
Daniel
geposted Mon 06 Sep 10 @ 7:27 am
What skin are you using and are you right-clicking?
Huey
Huey
geposted Mon 06 Sep 10 @ 11:57 am
Do you have safe mode enabled under CONFIG -> Performances
if so, try turning it off.
geposted Mon 06 Sep 10 @ 12:15 pm
