Hey there guys, looking for some help here...
Im running 2 3700s and a dnx1600, i can get the cd decks to control vdj and play audio through thier soundcards, so thats all ok.
What i want to do though is channel the sound through the 1600 soundcard.
I have disabled the 2 37s in the denon asio manager and have the 1600 enabled, then when i go in to config on vdj i cant get the sound to come through the mixer at all using any options.
I have tried it with traktor le and it works fine, but im a VDJ man :-)
Im using:
Samsung q45
1.83ghz pro core duo
3 gb ram
windows vista 32bit
thanks in advance
Im using:
Samsung q45
3 gb ram
windows vista 32bit
thanks in advance
geposted Tue 07 Sep 10 @ 11:50 am
Let's start from the obvious: have you installed drivers for DN-X1600? Are you able to use the mixer's sound card with any other software like WinAMP, Media Player etc?
geposted Tue 07 Sep 10 @ 12:57 pm
You need to set the sampling Freq on the X1600 to 44.1kHz
VDJ does not support the default setting of 96kHz.
geposted Tue 07 Sep 10 @ 5:23 pm
