I Have unfortunately many files without genre ,or incorrect Genre.I would like to know if i can rectify this on bulk by folder so that each file in folder gets labelled. any help would be appreciated.Ta
geposted Wed 08 Sep 10 @ 3:23 am
Bulk changes are not supported in VDJ6, however you can change the files in an external editor like Mp3tag then select them in VDJ and right click to reload tags when it will add the genre information (hopefully)
That should work!
Keith
That should work!
Keith
geposted Wed 08 Sep 10 @ 6:34 am
i have the same issue.
Thanks kieth
Thanks kieth
geposted Wed 08 Sep 10 @ 8:32 am
ta keith, i'll try that.
geposted Thu 09 Sep 10 @ 2:56 pm
Just tried it and it works. Just select more than one file in the VDJ browser then File infos > reload tag
Keith
Keith
geposted Thu 09 Sep 10 @ 3:03 pm
