When I'm searching for a video on hard drive, I get a dramatic pause of about 5 seconds before the song I'm looking for shows up. When I'm in haste this is a BIG problem. Does/ Has anyone else have/ had this problem and what did you do about it?
HP Pavillion, Intel Duo Core 2GHz, 4GB RAM, 285GB Hard Drive, Music ExHD 500GB, Video EXHD 1TB
geposted Wed 08 Sep 10 @ 10:46 am
Hey mate,
The delay is usually caused by the file sorting options you have the search results set to display as!
I would try and sort the list by 'Name' or 'Artist' first and see if this helps your situation.
Good luck!
DJ Lay Z =Þ
Good luck!
DJ Lay Z =Þ
geposted Wed 08 Sep 10 @ 10:54 am
