Hello guys,
Some friends recommended an audio interface by MAYA 44 USB to use with virtual dj.
Anybody could help me with audio interface?
Because i need to buy one interface but i would like of the others opinion about this issues.
Best regard.
Best regard.
geposted Sat 11 Sep 10 @ 10:42 pm
Do you have a budget? Do you plan to use time codes?
geposted Sun 12 Sep 10 @ 11:44 am
i use the hercules deejay trim and i am very happy with it. very good sound card and you can run timecoded with it.
geposted Sun 12 Sep 10 @ 12:42 pm
Thanks for reply!
So....depends........i intend to buy an audio interface, but this interface is an external sound board and i will use time code. Because i have two CDJ denon 1000.
Could you indicate me any sound board to use with virtual dj? But i will use time code.
Best regard!
Best regard!
geposted Sun 12 Sep 10 @ 7:46 pm
Well there's lot of options, some of the cheaper ones are
MAYA44
American DJ Versa Port
Umix-44
these are all 16bit sound cards
If your willing to pay a little bit more you could get something with higher 24bit quality
Hercules Deejay Trim
Native Instruments Audio 4
Native Instruments Audio 8
You could also get a Hercules MIDI controller with built in sound card, these allow you to do time code also
Hercules MK2
Hercules MK4
Hercules RMX
Theres soooo many sound cards but these are a few of the basics.
MAYA44
Umix-44
Hercules MK2
Hercules MK4
Hercules RMX
geposted Sun 12 Sep 10 @ 8:57 pm
I have the maya44 as a backup and never had a problem without and you an use timecodes with aswell.
Huey
Huey
geposted Sun 12 Sep 10 @ 10:12 pm
Thanks a lot guys!!!!
geposted Tue 14 Sep 10 @ 9:21 pm
im getting a Native Instruments AUDIO 2 DJ USB Soundcard thats good right
geposted Fri 17 Sep 10 @ 9:15 pm
i use maya44 befor no problem with cd time code but if you want to go pro. get numark virtual vinyl.
any one hire have hercules deejay trim coz i got mine yesterday and im having problem with it. ican hear the timecode signal from input 1n2 going out to output 3n4 im working on windos vista amd core duo 2.0. and 2gig of ram
geposted Mon 15 Nov 10 @ 7:25 am
