ok trying to do timecode_bypass on mapper for bcd 3000 i know it can be done it used to work anyone know what i need to put into the fields i have tryed a few dif things but no luck thanks !
geposted Mon 13 Sep 10 @ 1:53 pm
This is an VDJScript Action which only works with at least v6.0.
Greets, Heiko
Greets, Heiko
geposted Mon 13 Sep 10 @ 2:04 pm
ya i'm using 6.0.2
geposted Sun 19 Sep 10 @ 2:42 pm
Try
DECK 1 TIMECODE_BYPASS"
Huey
Huey
geposted Sun 19 Sep 10 @ 3:54 pm
em i had it working for about a min then i went to do the same thing for deck 2 now i can not get 1 or 2 to work :(
geposted Sun 19 Sep 10 @ 10:44 pm
Try updating to the newest version and see if that makes a difference. Let us know how it goes.
Huey
Huey
geposted Sun 19 Sep 10 @ 10:52 pm
i'm just not typing something in right i got it to work tho by some act of god haha deck one is good now just having trouble getting deck 2 so i can have a bypass button and a active button it seems to only want one or the other . i applied deck 1 timecode_active to ext in a button and deck 1 timecode_bypass to ext in b button on bcd3000 and deck 2 timecode_bypass on the cue a button but when i put deck 2 timecode_active on cue b it just does nothing
geposted Sun 19 Sep 10 @ 11:28 pm
I couldn't get it to work on mine either, tried all the correct code, let me know if you figure it out. Oh and I was trying to map mine to a korg kontrol
geposted Mon 20 Sep 10 @ 12:33 am
Your version is one of the first v6 releases which came out. There are no such problems in the actual release. Register, download and be happy.
Greets, Heiko
Greets, Heiko
geposted Mon 20 Sep 10 @ 2:35 am
Well I have it workin and you type in "deck 1 timecode_bypass" "deck 2 timecode_bypass" and its been workin since forever.............
Huey
Huey
geposted Mon 20 Sep 10 @ 6:36 am
Huey
yeah great but what buttons do you have it mapped out to do you just leave everything els alone?
Huey
geposted Mon 27 Sep 10 @ 1:20 pm
Greets, Heiko
oh thanks for your controller expert answer to a ? i never asked now i know someone out there knows how to make this work . cause i can get it to half work but then another button or feature will not work or will do something it is not supposed to
Greets, Heiko
geposted Mon 27 Sep 10 @ 1:24 pm
There are many problems with this old release. So you should update to the latest version.
Heiko
Heiko
geposted Mon 27 Sep 10 @ 1:30 pm
try the ol' pay_for_it button
geposted Mon 27 Sep 10 @ 3:55 pm
Hahaaa!! Chuck thats good, lmao!!
geposted Mon 27 Sep 10 @ 5:53 pm
