Hi,
I have CDJ 1000 with DJM 400 and i would like to record a session on my computer ... i think i need to connect RCA cable on the master output and connect it to the computer(in the input on a microphone)..
But what good program should i use to record ?
Is there also a better way to do it ??
Thanks
Thanks
geposted Wed 15 Sep 10 @ 5:53 pm
the master output 2 to line in on your computer then go to the record tab and chose line in. there are a lot of sound recording programs. just google for it.
geposted Thu 16 Sep 10 @ 12:16 am
i generally use this software to record all my mixes. its freakin awesome!
geposted Thu 16 Sep 10 @ 3:12 am
+1 on that I use the same software, seem to be offering free "lifetime" upgrades totally Awesome
geposted Thu 16 Sep 10 @ 4:31 am
Lucky you, I have pro and the recording software hasn't worked since I had the LE version. Everything sounds fine while I'm mixing, but the final product bleeds out the sounds in cue. Still waiting for an answer from the support team. I will be an unhappy customer if I have to buy a digital recorder (iKey HDR7 or Tascam DR 07). I'm optimistic the support team can resolve this without forcing me to shell out $140 for a recording solution.
To show I'm not hijacking your thread, I recommend High Criteria's Total Recorder....it records anything that is played on your computer...I mean any sound from any source (ensure you turn off email notification sounds, windows sound alerts, etc....).
J.
J.
geposted Thu 16 Sep 10 @ 2:46 pm
@LuckyLucien:
Have you tried to set the "Line-in" as a recording option BOTH on VDJ and Windows recording mixer?
I have found that sometimes you need to check BOTH of them in order to record propertly with VDJ.
geposted Thu 16 Sep 10 @ 5:40 pm
why not uninstall reinstall ?
geposted Fri 17 Sep 10 @ 12:59 pm
@PhantomDeejay
I have found that sometimes you need to check BOTH of them in order to record propertly with VDJ.[/quote]
No I have not but I will try this evening. Thanks for the recommendaion.
@Chuck, yes, I did uninstall, reinstall when it was the LE version, likewise with the Pro version.
Thanks fellas for the feedback.
J.
J.
geposted Mon 20 Sep 10 @ 12:14 pm
