ok here is my problem.
well first of all this is what I use.
- my personal computer. I dont have a super computer so i use LISTEN2MYRADIO
- I have used winamp and i can hear on both listen2myradio and shoutcast.com (on shoutcast it takes about 15 min to be listed, everything is ok so far)
- winamp you cant use a mic no more soo....I use this virtual DJ now (which btw its way better than winamp imo)
- now on virtual DJ i go to broadcast>> use my listen2myradio IP + port + password + add my station name and put geres>> I click use shoutcast>> i use 64bit rate (just in case for it wont skip) >> on the encoder part which is lame_somthing somthing ( i leave it alone).
I press start recording IT WORKS!! i can go to listen2myradio and hear it!!
BUT!!!!
When i go to shoutcast its never listed. I wait the 15 min....nothing...i wat 20 min......nothing.......i wait 1 hour.......NOTHING!!
This is my problem. if anybody knows what I need to do please respond. because i would like it to be listed on shoutcast please.
BUT!!!!
geposted Thu 16 Sep 10 @ 9:06 am
I guess you should talk to the support of shoutcast.com
You have done the right settings inside VDJ.
No more the soft can do! IMO
geposted Thu 16 Sep 10 @ 9:59 am
