Hey guys im new to the forum and I need your help!
I have the numark total control and dj io. Total Control plugged into my laptop and works fine. However the DJ IO is having some problems. Through the DJ IO in output 1 i have a set of speakers, and through the headphone jack I have ... well headphones.
My problem is this:
My left deck comes through the speakers, but the right will not. The right deck will only play through my headphones.
What I want is to be able to preview tracks through my headphones and have both channels comes out the speakers.
http://i30.photobucket.com/albums/c313/Rebeccabek/vdj.jpg
Help please?
Thanks guys,
Rebecca
My problem is this:
Help please?
Thanks guys,
Rebecca
geposted Thu 16 Sep 10 @ 12:45 pm
Have you checked the output settings in the sound config Menu? Try setting it to master: Chan 1&2 / headphones: Chan 3&4
Then select your DJIO as your sound card.
Edit:
Sorry that only works if you are a VDJ Pro user. You Might want to look at your PC/lap tops sound hardware and see if you can adjust the settings from there.
Edit:
geposted Fri 17 Sep 10 @ 2:18 am
