how about a way to change how the volume behaves when fading in and out of a song? example...a scratch fader evokes a behavior different than a mixing fader.
is there an option to change what fader-type i can use?
geposted Wed 15 Jun 05 @ 11:03 pm
Yes, it exists :-)
Download my plugin Crossfader Curves
It's my little baby ;-)
(If you activate the plugin you can define the curve as you want otherwise there are curves registered in the button behaviors)
(You have only 3 mode included by default in VDJ: smooth, full,cut)
Besides i could do the same thing for Level in the future :-)
geposted Wed 15 Jun 05 @ 11:15 pm
djwarrior,.. use a real mixer if you want a real xfader :)
geposted Thu 16 Jun 05 @ 3:20 am
