Hi guys
I have the latest Pro version of the software, but I noticed I no longer see the Safe Mode or Overclock Option in my config menu. Was this removed?
Also on some heavy bassed house songs I will get the occasional hiccup or like a half-skip, its not a pop or a click, just like a mini skip or the bass will totally drop out for like one beat
I have a macbook Pro 2.53 ghz Dual core Proccessor
2gb DDR3 SDRAM
Hercules RMX
I have my Config setting to Best Quality and Latency to Auto
Is this a USB Droppout? How do people use a powered usb with the Hercules RMX? Doesnt the laptop and the RMX need to talk to each other? Are they both plugged into the Powered usb hub?
Is it the Hercules RMX Soundcard causing this?
I want to upgrade my ram thinking this would solve the issue but according to the specs I have the Reccommneded specs no?
All my files are AAC 128 and 256kps
Thanks for all your help
2gb DDR3 SDRAM
Hercules RMX
geposted Fri 17 Sep 10 @ 2:49 pm
Try change the USB port.
geposted Fri 17 Sep 10 @ 7:42 pm
Thanks for the reply
I think I figured it out...It seems to happen when I have the Keylock On
geposted Sat 18 Sep 10 @ 12:06 am
