Did a search to see about syncing my playlist from one laptop to another and didn't really find what I was looking for. I have learned I can't just copy my playlist from one to the other unless each machine is set up exactly the same, but they are not and not sure I can' set them up the same. Different brands and each has their own hard drive set up it seems.
Is there a way to sync up my playlists using Network Sync under Multi Instance? Or do I have to remake each playlist from scratch?
geposted Sat 18 Sep 10 @ 6:56 pm
As long as both database are the same, then just copy the playlist to the other machine and it should work..
Joey.....
Joey.....
geposted Sat 18 Sep 10 @ 8:06 pm
Like Joey said just copy it and it will work.
Just be sure to put the play list into the VDJ folder play lists.
geposted Sun 19 Sep 10 @ 6:31 am
I tried that and it did not work. Would it be because on one lappy my music is on drive d and the other machine my music is on drive g?
geposted Sun 19 Sep 10 @ 7:32 am
Sounds like that is the case .....
You can download pspad or a similar editor and do a find & replace on the playlist to change the file location.
Always keep a seperate backup of the playlist first in case anything goes wrong.
geposted Sun 19 Sep 10 @ 8:58 am
I'll try to rename partitions using the Disk Management feature and see what that does for me. Since I'm a still a fairly new user of the software, I don't have many playlist to worry about at the moment, but that will change of course.
Thanks for the help.
geposted Mon 20 Sep 10 @ 11:44 am
