Right guys got myself a new machine, So i copied over all my files that makes virtual my own lil virtual. But i screwed up on my harddrive and it assigned my external as H and not G, Now my playlists and history dont work. I tried to uninstall the usb drivers and it still aint working. Can i change the file name from G to H.
any help would be great
Thanks Chris
geposted Sun 19 Sep 10 @ 7:46 am
I'm assuming you are running on Windows 7.
Go to Start ->Right Click on Computer->Click Manage->Click Disk Management under Storage (you may have to click on Storage to open)->right click on the disc you want to change->Change Drive Letter and Paths->Click Change->Where is says Assign the following drive letter select what letter you want the drive to be.
Hope that works for you.
geposted Sun 19 Sep 10 @ 8:43 am
Some man cheers buddy!!
geposted Sun 19 Sep 10 @ 8:47 am
