Hi there. I'm having some trouble with my HERCULES RMX. i would like to use my RMX as a general mixer listening to windows sounds through the RMX. sometimes it works fine selecting WDM instead of ASIO, but Iopen VDJ and ASIO error message appears n Windows sounds are Lost. as many or VDJ users a wish to listen and play DVDs on Virtual DJ, but it seems VDJ is not ment for it. Does anyone know haw to get Windows sound such as WMP through th RMX? thnks allot!
geposted Mon 20 Sep 10 @ 6:11 pm
Windows and the rmx will allow to use either asio or wdm but not both at the same time. You can set up the rmx to work with vdj pro with the wdm drivers. so when you shut off vdj you will get your windows sounds back.
geposted Mon 20 Sep 10 @ 9:23 pm
