Forum: Old versions
Topic: echo loop effect
Greetings. Has any one out there written a script for an echo loop effect similar to the echo loop on the Pioneer DJM-909 and the Denon DN-S3700. I've just been using the loop by itself and fading out but its not the same. (to me).
Any ideas are greatly appreciated.
geposted Tue 21 Sep 10 @ 8:16 pm
Thanx. Are you using the numark box too?
Yup until Serato releases the drivers for the SL3. I think its a pretty good box, never have had any trouble with. I've had it for about 3 years now and still goin strong!!
Huey
sweet. I cant get the plugins to load onto Virtual Vinyl? any suggestions
Do you keep getting an error that says "VDJ Not Found" or something like that? If so you could always upgrade to VDJ for $49. Just go here, https://virtualdj.com/buy/ and just enter you NVV serial number and your good to go.
Hope that helps
Huey
I too have been looking for the echo loop effect like in the Denon DX1500 Mixer, with the 3 links given above, does this mean I can get that same effect using VDJ and those plugins?
