Topic: out of usb ports what to do?
Ok here's my set up:
2 American Audio Radius 3000's
Connectiv sound card
My passport usb external hard drive
Samsung i5 laptop with 3 usb ports and 1 HDMI
Is there a solution out there that will allow me to hook all of this up ?
geposted Wed 22 Sep 10 @ 8:58 pm
I have a Hercules controler, wireless mouse, 2 TB HD, NI DJ2 audio and a 4 way powered Usb hub I have 2 Usb ports on my Vaio
Hmm..............have you tried a USB Hub. Do some research as there are many hubs out there. The only down side I can think of is, to many things tryin to go in and out of a small space. Kinda like tryin to get on the freeway in rush hour traffic, lol!
Hope that helps and makes since
Huey
ok great! I didn't know if I could use a hub with vdj.
Thanks!
u should definetly go with a POWERED hub
yes definitely powered and definitely keep spares
If your laptop has eSATA port then you can make it as your 4th USB port.
I use it for my Audio8dj, the rest are for the CDJ400 x 2 and external drive or extra midi controller.
yeah or if it has fire-wire you can go that way also...
I have a powered hub but I avoid usuing it because it never seems to find my RMX.
I use a powered 7 port hub that I bought from Guitar Center and it works flawlessly...
DJ RuDe
