Hi everyone I'm using 5.2.1 and was wanting the optimal settings that you use to get the best quality. I'm using Denon HC4500 sony vaio i5 Processor 6gig of ram windows 7 home premium 64bit. many thanks
geposted Fri 24 Sep 10 @ 11:12 am
Does no one use 5.2.1 anymore?
geposted Sat 25 Sep 10 @ 2:04 am
With the specs of your pc ... i just have a question... why you are not using the lastest version ? V.6 has more quality in the sound engine i think... so .. with the same parameters youre using on 5.2.1 you will get better sound and performance...
geposted Sat 25 Sep 10 @ 2:32 am
Im not using the latest version because I Like JPboggis Mapper I don't like the one with the latest version even though you can map the controller the way you want it. I find this to difficult. If there was a mapper just as good as JPBoggis then I would use the latest version.
thanks for the reply
geposted Sat 25 Sep 10 @ 3:16 am
which Jpbogis mapper ? edit the mappers is fast with the new soft...
geposted Sat 25 Sep 10 @ 3:19 am
It is in the pluggins section of the site but only works with 5.2.1 do you use the HC4500?
geposted Sat 25 Sep 10 @ 3:41 am
No but but i can try to configure the mapper by editing the xlm and testing it with the hc4500 of a friend of mine... i'm gonna check & let you know...
geposted Sat 25 Sep 10 @ 3:45 am
Why don't you send JP a message and ask him nicely if he would make an XML file which is mapped the same way?
The advantage of this being that he could upload it and make it available to any fans of his original...
geposted Sat 25 Sep 10 @ 3:54 am
acctually that sounds like a good idea...
geposted Sat 25 Sep 10 @ 3:56 am
I think he has already been asked I may be wrong. I do appriciate the help. I have a gig tonight and i'm gonna stick with 5.2.1 tonight and see what happens next week
geposted Sat 25 Sep 10 @ 4:17 am
