I am having issues with the video freezing every time I manually mix any videos. The video will freeze or lock up (audio still runs fine) after the croosfading from one song to another. There is no set amount of time, it happened Tues I restarted the computer and it did it after the first mix. BUT, I can run videos in automix all night and the video works fine all night. I turned in a support ticket 3 days ago and have heard nothing back. Also, I saw there was another post on here with my same issues and computer but he was using a cracked copy (I have legit pro). Here are my specs any help would be great. Thanks in advance.
Asus g73-jh
ProcessorIntel® Core™ i7Processor Speed1.6GHz (with Turbo Boost up to 2.8GHz)
Display TypeHigh-definition widescreen LED-LCD (1600 x 900)
System Bus1333MHz
Cache Memory8MB on die Level 2
System Memory (RAM)6GBSystem Memory (RAM) Expandable To 8GBType of Memory (RAM)
DDR3Hard Drive TypeSATA (7200 rpm)
Computer Hard Drive Size500GB
GraphicsATI Mobility Radeon HD 5870Video Memory1GB GDDR5
windows 7 home 64-bit
using vdj 6.1.2
Thanks again
Asus g73-jh
System Bus1333MHz
using vdj 6.1.2
Thanks again
geposted Fri 24 Sep 10 @ 3:26 pm
