Hi guys.
Im having some trouble setting up virtual dj to work with 2 cdj 400's.
The trouble is that even tho i got 2 songs playing at the exactly same BPM with 0% pitch they still eventually go unsynchronized so i have to keep nudging one of the songs too much... im guessing its some kind of configuration that is not set up correctly because i didnt have this kind of problem with the other software i currently use.
Heres how im setting up Virtual DJ:
Inputs - none
outputs - external mixer
sound card - 2 cards (each card being a diff cdj400)
on performances ive tried both fastest and best quality presets but it didnt fix the thing.
What do you guys think?
maybe i should use the asio drivers?
Thanks in advance.
Inputs - none
Thanks in advance.
geposted Sat 25 Sep 10 @ 5:24 pm
Yes, you should use the ASIO!
geposted Sat 25 Sep 10 @ 11:25 pm
WHere do i find them? do u have some kind of sample config to provide so i can use as reference?
Thanks for answering.
geposted Sun 26 Sep 10 @ 3:37 pm
