Has anyone successfully gotten TouchOSC running on a Ipad/Ipod to control VDJ on a PC? I've been trying to get it to work but I've been hitting some roadblocks.
geposted Sun 26 Sep 10 @ 2:05 pm
Yer I was thinking of getting an iPad for my DAW.
Turns out the apple guys say it can't be done. Long story short, it's just a fat, over priced, iPod touch - litterally :(
The only apps you can use are the ones issued from the apple store (so not even mac apps from the net), can't use it as a phone either...
So, it's not a laptop, not a mac book, nor a computer it's just a peice of @#$
OK, so this turned into a review rather than help... As far as the mac guys say, it can't be done but maybe if you managed to jail break it?
Don't ask how mind, got no idea
geposted Fri 01 Oct 10 @ 10:16 am
All it needs is development of custom midi interface which is not impossible but there is nothing available at present specifically for VDJ.
You can however control VDJ on the ipad perfectly well by VNC as posted here:
https://virtualdj.com/forums/129732/General_Discussion/Control_VirtualDJ_via_an_iPad.html?search=ipad&page=1
The ipad is a very capable piece of kit actually .......
geposted Fri 01 Oct 10 @ 11:32 am
Yes it does work now on the PC, I've seen it. I'm just having problems installing the OSC and Yoke software. That's what I need help with. Check out Youtube, some people have it working.
geposted Fri 01 Oct 10 @ 11:57 am
My setup...
geposted Mon 18 Oct 10 @ 2:06 am
My setup...
Intel Mini-ITX Motherboard
Intel Core 2 Duo 3.16Ghz
4GB Ram
(2) 2TB SATA HD
Audio 8 Soundcard
2 iPads running TouchOSC w/ custom templates and PureData coding
Custom built mixer w/ UMC32 usb-midi controller / navagation section & innoFADER
MidiFighter w/ 16 arcade buttons for quick cues, samples, loops, etc
Traktor Pro
Virtual DJ 7
DVI, HDMI, VGA or composite video out
2 Pico Projectors
4 low lux cameres
CCTV Quad switcher for camera feeds
Wireless video DVR for desktop / visual monitoring
Sony wiresss headphones
PS3 Bluetooth remote (Custom coded for Virtual DJ use)
4GB Ram
(2) 2TB SATA HD
Audio 8 Soundcard
Traktor Pro
Virtual DJ 7
2 Pico Projectors
4 low lux cameres
geposted Mon 18 Oct 10 @ 12:16 pm
DJdab, what configs did you use for pure data?
geposted Mon 18 Oct 10 @ 12:37 pm
Initially I used this tool to covert my templates to midi and then I slowly learned how to tweak them...
http://hexler.net/pure-data-patch-generator
geposted Mon 18 Oct 10 @ 12:54 pm
Thanks, I'll try it tonight. By the way, great setup. Can you scratch with it ok?
geposted Mon 18 Oct 10 @ 1:16 pm
Well, I was able to emulate decent scratch wheels but if I really want accuracy I use Tonetable for timecode to VDJ. That is pretty precise.
geposted Mon 18 Oct 10 @ 2:01 pm
That's damn geeky! :D It made my day :D
geposted Mon 18 Oct 10 @ 2:28 pm
Thanks ;o)
geposted Mon 18 Oct 10 @ 2:38 pm
Brilliant man. I love this. I have been trying a few of the apps out there to try and figure how to run VDJ with my iPad. You are awesome :-)
geposted Mon 18 Oct 10 @ 2:50 pm
