how do i stream live video/camcorder to screens.
was using automix at start of gig saturday and nearly last song it went choppy and deck became unresponsive for a while no crash anyone know why.
when using slideshowcan you make photos the same size without distorting actual image.
just want to add i havent had a crash in over a year just always learning bits to move forward bit by bit
geposted Mon 27 Sep 10 @ 1:22 pm
ive installed my webcam and it appears in Effects > Video Effects > Device...
then click Activate and after a few seconds the camera streams to the video screens.
(but there is a slight delay in getting the imaga, i thought this might be down to my camera drivers)
geposted Mon 27 Sep 10 @ 8:26 pm
ill give it a go mate thank you for responding
geposted Thu 30 Sep 10 @ 1:08 pm
If you are using a video capture device, It may work better if you only install the drivers, and not the software. This way there is not a conflict between the two soft wares trying to grab the drivers at the same time.
geposted Thu 30 Sep 10 @ 5:17 pm
