I took the Vms4 out on a gig last night,and I had problems with the 2 and 3 channels. The music just played on one channel...I couldn't hear it in the headphones also..then it froze on me.......error with wow popped up.... can anyone help me with his issue......I have vdj pro also.
geposted Mon 27 Sep 10 @ 8:13 pm
You know when I 1st tried using my VMS4 the same thing happened to me but only when using the LE version, I didn't have that problem in PRO
geposted Tue 28 Sep 10 @ 12:08 pm
Thanks its working...cool...now. Now..the configure screen pops up when I turn the eq knob.
geposted Wed 29 Sep 10 @ 9:35 pm
well i have had my vms4 for at lease a month now and i have had a few probs but so far its workin ok just 1 thing the mike i cant get it too sound right a bit quackish still tryin too sort that oh can any one help me out with some samples i heard two for the vms4 on youtube in the mixes the guys have up
geposted Thu 30 Sep 10 @ 9:29 am
what i can tell u is too check the latency in config for the aiso driver make sure the setting is not set too the smallest setting that can cause the frezz but for the channel make sure that the sound card setting is right and also aiso setting make sure that u have the right channel select and make sure that the vdj setting for the jog sensitivity is not too its highest
geposted Wed 06 Oct 10 @ 7:59 pm
can the jog wheal be adjusted on the vms4 like how the vextex do with the little screw at the side and like the Hercules cause i find it spends fairly freely some times and when i scratching it moves too far forward when i release
geposted Wed 06 Oct 10 @ 8:02 pm
BaronBOOm How did you get it working because I have the same issue using pro??
geposted Sat 16 Oct 10 @ 8:14 pm
i just had to go to config > sound setup > advanced > ASIO not VMS4. and it worked on ch3 and ch4 . hope that helps.
geposted Sun 17 Oct 10 @ 9:11 am
I am having the problem with sound only coming out on left side for both decks. I am using VDJPro, Windows XP 64 Bit. I like using the 64 bit because the sound is great, no latency with no tweaks. The only problem is no matter what adjustments I make I can only get sound when I use Sound Setup - Advanced Config - VMS4 - Output 1&2. If I use ASIO or any other configuration, there is no sound.
The VMS4 works fine with Windows XP 32 bit. But the sound isn't as good. Also, I don't have latency problems when I use the Numark Total control.
Any help would be appreciated. I called American Audio Technical support and they treated me like I was an idiot.
geposted Thu 16 Dec 10 @ 5:45 pm
I'm also having a problem with the VMS4 playing the VDJ Pro on the same channel. Even if the assign knobs are on different channels, it still seems to play both decks on the same channel. Then my crossfader stopped working. When it's on the left, it'll play both decks, and shut the music OFF when the crossfader is on the right side. I know I probably set it up incorrectly due to my excitement when I got my new toy, but please, someone, help me fix this. My new toy is no fun if it doesn't work properly. I followed the Quick Set-up guide that came with the VMS4 but it still isn't working right. My hardware also seems to be opposite from my software. If I load a track on the right side, I would control it on my VMS4's left side. The "normal-reverse" knob only controls the crossfaders output into my headphones. How do I fix this too? I need my software to MATCH my hardware...HELP!!!
geposted Tue 28 Dec 10 @ 12:37 pm
you need to update the firmware of the console, you can download it from here http://www.vms4dj.com/Files/vms4-firmware311.zip , read the pdf instructions before update.
geposted Mon 10 Jan 11 @ 9:40 am
Manquin how can I tell what firmware I have or if I need to update. Cause I used the update that came with the disk when I first it....or is there a more recent one?
geposted Mon 10 Jan 11 @ 5:16 pm
yes there was a little bug with the firmware included in the disk so you need to download that one from the official site
geposted Mon 10 Jan 11 @ 11:33 pm
don't mean to jack the thread:
manquindj can you tell me your settings for the vms4 to use with TC if you see my post i am having no luck and dj dad said yours works fine. can you post your settings in the thread. thanks.
geposted Tue 11 Jan 11 @ 3:30 pm
